Need help.. I need to retrieve data or files which is already formatted in the laptop. I was trying a software for recovery but still after it scan, it was not able to view the files.
Is there other way to solve my problem? I haven't have other software for recovery to do this..
Please help me..
Hallo Jhobugz,
To recover your formatted data or files, you can use data recovery programs. One such application is the Aidfile data recovery software that will help you recover all files from from formatted hard drive, for instance:
So what you will need to do is go to the internet is download a copy of this application, install it on your computer and the after that execute and use it to recover the files that you lost as you formatted your computer or whichever gadget.
Hope this helps.
Carl
Hi Jhobugz,
There are a number of file recovery softwares that are available for free on the internet e.g
For instance if you decide to download and install getdataback , then most important thing would be to locate the drive in which your formatted files were located. Recovering files from the entire computer might take along time.
Follow the following steps to recover your formatted files.
2. Select the source you want to perform data recovery on.
3. Select range to scan and the file system you want to recover then click on next button.
4. The application will start recovering formatted files and photos.
5. Go to file menu and click on save recovery. The recovered files will be saved in a folder from where you choose an appropriate application to open with.
I hope that this information will help you recover your formatted files.
James B. Areba
