Required software is missing or not running
Some days ago I downloaded Revoice Pro License in my computer. Today I run its setup but it gives me this error message which you can see in the attached image. I need your assistance. Thanks
Revoice Pro Cannot run
Problem: Authorization Error: Revoice Pro Cannot run. The required software is missing or not running. Please reinstall the product or download and run the driver installer here: https://www.paceap.com/
Best Answer by Fraserr Dawn
Answered By 0 points N/A #173123
            Required software is missing or not running, I think it’s either the software needed is not installed or it’s missing in the network. What you need to do first is to find the requirement of the software Revoice pro license and the other option is try running it as administrator or change the “user account control settings to lowest level.
Answered By 0 points N/A #173124
Hello Wayne,
The Revoice Pro might have updated it's version and expired the old version which you are trying to install. The solution is simple just download the fresh copy of Revoice Pro and install it again. Also make sure all your drivers are functioning properly. You can check this under Device Manager. If there is a driver issue, reinstall your driver and install the software again.
