Required loader for iPad to install applications
My brother newly purchase iPad and does not know how to add games and other applications in iPad .
I think there must be a loader for iPad to install applications.
Which website providing free loader to load and install applications in iPad ?
Best Answer by Clark Henf
Answered By 0 points N/A #146364
There are two ways to download or add games to your iPad.
One way is to find App Store in your iPad(make sure you have an internet connection). Search the title of the game that you want to add and click download (before you can purchase games, you should have an account in App Store, so you can pay for the game that you want). Wait for it to finish downloading and you can already use it.
Another way is to install iTunes in your computer. Connect your iPad to your computer and open iTunes. You will your device connected there. Visit iTunes Store and search for the game that you want. Click download (again, you should have an account to do this).
Wait for the game to finish downloading and then click your device on the left part of the screen. From the tabs, select applications and then click your newly downloaded game to transfer it to your Ipad. Click Apply.
Hope this helps.
Good luck!
Answered By 0 points N/A #146365
Hello.
There should be a loader so that you can add and other applications to your IPad.
IPad loader can be downloaded from the following website for free.
Click on the below link to download loader.
After downloading and installing loader connect you IPad to your system through connector.
After a successful connection you can add games and other videos to your IPad.
Thank you.
