Renaming my tabs according to bookmarks
Hi all, I user Google chrome as my default browser and just like all the other users, I have a lot of bookmarks saved already. I am looking for an extension/plug-in which could rename my tabs by the name they were saved in the bookmarks. Two questions; is it actually possible or not? If yes, then please let me know how it is. Thanks!
Answered By 0 points N/A #183522
For renaming the tabs to display the bookmark name below given are the steps to be followed:
  • From Chrome webstore download and install the extension called "Tab Title Tweaker".
  • Open the chrome://extensions  in chrome to define the set of rules.
  • Tab Tweaker Options page will be displayed.
  • You can use the below options to rename and save the rules with which your tabs will be displayed:
  • “rename “ – to completely replace the tab title with your own text
  • “prefix” – to add text to the beginning of the tab page title
  • “suffix” – to add text to the end of the tab page title
  • “revert” – to reset the title to its original value
One sample rule to be used is given below.
For example : rename google.com goog
Create the rule and then save the same in My Rules tab.
