No of visitors who read this post: 201
Category: Internet
Type: Question
Author: Ryan Abate
Your rating: None Average: 5 (1 vote)
Hi there! There is a new software released recently called the Toolwiz FlipBook 1.4.0.0, and I have heard that this program transforms text file into a 3d e-book! Is this true? Can anyone tell me whether the theme colour of the program can be customizable? Which operating systems does it support? Thanks.
Comment viewing options
Hi Ryan,
Toolwiz Flipbook is a freeware that you can convert a text file into 3D ebook format with onle few clicks. This said freeware can support Book Name, Author Name, Customized Font, Width and Height. It supports more than 200+ effects while flipping the book. You can use Space, Up, Down, Left, Right key to read the book ina flipping way easily.
Also, It can change and customized the theme color. It also suppoprts comment mode which allows you to scrawl on the book and it will remeber the last page you visited when you close it. Also, does have a Full Screen and Normal Screen mode. This freeware supports Windows XP/Vista/7/8 Platforms.
Hope these information might be helpful to you. =)
regrads,
Edwin
