Reference Manager tool compatible with Word 2007 and 2010
I need a reference manager word tool that is compatible with Windows Word 2007 and 2010. Please suggest me the best reference manager that will Quickly search & select citation style and will help to create an own citation style and will format citations & bibliography based on the chosen style. One of my friends is using a Mendeley reference manager, which is available for free. Please suggest me the best free version of reference manager other than that of Mendeley. Thanks
Best Answer by Guy V Mohr
Answered By 0 points N/A #168141
Hey,
As you stated above that you are in need of a reference manager word tool that is compatible with Windows Word 2007 and 2010. The best reference manager that will Quickly search & select citation style and will help to create an own citation style and will format citations & bibliography based on the chosen style you can choose  from the link I am providing you which also explains about compatibility of  reference manager Hope this will help you a lot.
Thanks and Regards
Gillam Janetj
Answered By 0 points N/A #168142
Hello, Burris! I have known that you are looking for Reference Manager Tools for word 2007 and 2010. Well, you can firstly installed tool for 2007 can upgrade. In this way, it will be suited for word 2010. In fact, it will help you to create own style. As well as you will be able to format citations & bibliography based on the chosen style. If you are not able to get this update tool, I will suggest you visit this http://endnote.com/ website for the upgrade reference manager tool. Best of luck!
