Red light with my xbox 360
Hello, I have a Xbox 360 in which I am having a problem. A red light is appearing with a code like ERROR E79. I used troubleshoot but failed to get desired result. If you have some idea, then please let me know. Thank you.
Best Answer by Iamexpert
Answered By 0 points N/A #153277
Your business at your home just using computer and internet. To understand online business take an example into account, you need to purchase CD’s of some software from a shop for this you have to go to the shop but what if the shop present inside your home. So for software’s you just go to the internet and search, there are many websites for all software’s you can download those software’s from online shop, or you can purchase those software from online shops by paying through credit cards instead of going outside and purchasing the CD’s. Online business is going to be very popular
Answered By 0 points N/A #153278
Error E79 is a signal that your Xbox might already have a faulty hard drive. But to do a quick fix try removing the hard drive.
Before removing the hard drive, make sure that all the memory devices and cables have already been removed. Once the hard drive is removed, plug back the cables and restart your Xbox. The Xbox should not show any error messages by this time. You can try to re-install the hard drive, if it works, there should be no problem. But if it won’t you need a hard drive replacement.
