Recover Deleted File on a Shared Network
Hello techyv,
How to recover deleted file shared network? I was a network system administrator in a small business company here in our place. While my officemates are sending data through the network, there is an error occurred which the data sent was accidentally deleted by the person in the other end. How can we possibly recover deleted file in a shared network? We need to recover those important files as soon as possible.
Expecting some help from you guys. Thank you.
Answered By 0 points N/A #184692
Hello there!
if there is any chance that you're running it on win2003 you could try and check if your Volume Shadow Copies feature on that file server is Enabled. If yes then you could recover your file for this allow quick recovery of deleted files. If not then your files are really gone and there is no way of recovering those. So I must suggest that you enable it because things like this tends to happen again in the future.
Hope this helps!
