nadeemrao
Posted on - 08/09/2011
I am using RadScheduler of telerik control,and I am running into issues like when I select a date range to schedule a task for multiple days and it re-occurs after some interval like after every two days on that particular time.
But when I press save button, it schedules for a whole day.
What can be the reason?
andre
RadScheduler multiple date selection issue?
This could happen only under special circumstances. For example, if you are in Month view and you double click on a time slot to schedule an appointment, it will be an all-day event by default.
However, in Day or Week views for example, the appointment should start from the time slot you used to open the insert form.
Moreover, it looks like you are creating a multiday event (an appointment that spans more than one day).
Please, make sure that the start date and end date are the same. If you need to limit the recurring series, please use the End by option.
Please, elaborate on your case so that we can be more helpful.
Do you intend to create appointments that span more than one day or do you need recurring appointments.
