No of visitors who read this post: 1117
Category: Misc Software
Type: Question
Author: Mitchie
Your rating: None Average: 5 (20 votes)
I'm installing Quickbooks Pro 2011 on a Windows XP desktop. Each time I start the install I get an error:
"NETWORK ERROR OCCURRED WHEN ATTEMPTING TO READ FROM FILE E:\QBOOKS\MSXML[1] MSE" then I get "FATAL ERROR MSI 1603".
Comment viewing options
# (Solution Accepted)
Try copying the contents of the cd to a new folder in your desktop and run the setup file from that folder. You may also try to download the software and install at www.usequickbooks.com/pro2011 .
Any luck? Update me. Ok?
Currently downloading the installer off the internet, seems like my CD is busted, might call support to have it replaced as well.
Hi Gen,
I was able to install it using the setup files I downloaded over the internet. Appreciate the help though!
