Quantum 7487 USB Game Pad not working in Devil May Dry-5.
Asked By 25 points N/A Posted on -
I am using Quantum gamepad for playing games in my laptop. It is working fine for some games but with Devil May Cry-5, it is not working. I have enabled gamepad option but it is not responding. It is showing options for Gamepad and I have set the controls for it but when I start to play the game the Gamepad is not working all. Tell me some solution for this problem.
Answered By 590495 points N/A #183770
If you have a Quantum gamepad and it is working on some games except for the PC game Devil May Cry 5 from CAPCOM, check if Devil May Cry is compatible with your machine. If the gamepad is perfectly working on some of your games then there is no problem with the device.
The PC game Devil May Cry 5 works with Windows XP, Windows Vista, Windows 7, and Windows 8. It requires Intel Core 2 Duo 2.4 GHz or AMD Athlon 64 X2 2.8 GHz or higher, 2 GB RAM, NVIDIA GeForce 8800 GTS or ATI Radeon HD 3850 or higher, and 9 GB hard drive space.
Verify that your system is perfectly compatible with the PC game. If there’s no problem with the specifications and is perfectly compatible, I guess you should try updating your gamepad’s driver. Visit Quantum Drivers Download and then download the USB gamepad driver.
