QPR error Open-file failed – abort?
Hello, I have an error and I can't find any solution for it.
The error message is :
QPR Error
Operating system on my laptop is Windows XP.  I got the above error when using QPR.
It is the first time that I've had this error. Help from anyone who has faced this problem before will be appreciated.
Thanks for your time.
Answered By 0 points N/A #127822
Hi Murat,
QPR is a file extension for queries created in Visual FoxPro.
Normally, one encounters error in opening files in .qpr format due to registry related errors or if one has not installed an appropriate program or application. Since you already have this error message on your screen now, please click on the YES button.
Since this is a registry error, you can no longer open the program or application until it is resolved.
In order for you to resolve this issue, you must run a registry scan.
Here is a helpful link,
From Microsoft's Gold Certified Partner to run a free registry scan: .
I hope this resolves your issue.
Best regards,
Kirstyn Philips
