PS/2 serial mouse compatibility problem
Hi techyv;
My computer system is Pentium –IV 1.2 GHZ and mouse is PS/II A4Tech Scroll mouse but my systems’ motherboard doesn’t have PS/II port. I am using serial connecter to connect mouse to computer. Windows XP 2002 was installed on my system.
When I have installed windows 7 so it stops working. What is this problem?
And what should I do?
Please help me.
Thanks
Best Answer by Sharath Reddy
Answered By 590495 points N/A #89801
That is why it stopped because your computer’s hardware specification is on the edge of the minimum system requirements of Windows 7. Your system will perform slowly since you only have Pentium 4 1.2 GHz processor. Here are the minimum system requirements for Windows 7:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM for 32-bit or 2 GB RAM for 64-bit
  • 16 gigabyte (GB) available hard drive space for 32-bit or 20 GB for 64-bit
  • DirectX 9 graphics device with WDDM 1.0 or higher
You need to replace your motherboard to be able to install Windows 7 since your board only supports serial mouse types and your processor is very slow to be able to run Windows 7 efficiently.
Answered By 10 points N/A #89802
I have changed my system's motherboard and my problem has been solved.
I am very thankful to techyv. It is a good platform to solve IT based problems. Thanks you very much for your  help.
Thanks
