No of visitors who read this post: 168
Type: Question
No votes yet
I was wondering if somebody may help me to identify problem with Sigmatel S3 Mobile software? Whenever I start the application, it shuts down automatically. Does anybody know the cause and how to rectify this issue?
Comment viewing options
The only problem associated with this kind of behavior in an application where it automatically closes just after opening it is incompatibility with the operating system where it is running. If this is a new installation on your mobile phone, try rebooting your device then start the application again. See if there is a change in its behavior. If the application was downloaded from a mobile site, try visiting the site again then check the application’s requirements there if it is available. Or, if it is already installed on the phone when you bought it, try visiting the app store then check if you can find a different version that is compatible with your phone’s operating system.
You may also try upgrading your phone’s operating system to have a much wider range of program compatibility.
Regards
Sharath Reddy
