Randy Baier
30 points
Posted on - 03/17/2013
I’m installing MPEG to DAT converter on my MAC for the first time. A friend told me I need to install a program so I could correct MPEG errors and also convert VCD files to MPEG. This one has to be installed separately, I guess? But if there’s one converter that I don’t need to add another program, please show me.
Program for Mac mpeg to dat converter
If you need to convert your mpeg files to dat, try the Xilisoft DAT Converter. This is a good converter that can convert DAT, AVI, DivX, MP4, MPEG, MP4 and a lot more. You can download and purchase it from the link given below:
http://www.xilisoft.com/dat-converter.html
You can also try the Wondershare MPEG Converter. This is a powerful tool that can let you convert MPEG file to almost any video file. This is available in Mac. Just click on the link below to download it:
https://www.movavi.com/support/how-to/how-to-convert-dat-video.html
