No of visitors who read this post: 2059
Category: Windows 7
Type: Question
Author: HOWARDddACA
No votes yet
Its been about 3weeks since I have been using x4 and today I got the below error. I dont know what was the cause of this error. I have a windows 7 running very great but the error came uo. Provide some good advice on how I'll resolve this issue.
CorelDRAW
Product installation unsuccessful, please reinstall (Error 38).
                                                OK
Comment viewing options
This error comes because the “Protexis Licensing V2" services in Windows was disable. For solving this error you can do this:
Click Start, then point to Run and type: services.msc at the box
find “Protexis Licensing V2”, then start the service. After that change it to Automatic
Close the Services window, then restart your computer. That's all, now you won't see that error anymore.
But If you can't find the “Protexis Licensing V2" service, you can download from here:
Copy PSIKey_2.dll and the PsiService_2.exe, and paste them to C:\Program Files\Common Files\Protexis\License Service
Right click on file REG_Protexis_licensing_service_V2_fix[2010]-ihecker.reg, then choose Merge
After the service installed, edit the service from Computer Management, then restart your computer.
