I use Microsoft Exchange 2010 with service pack 2. I was initially a SP1 user but recently upgraded my system to SP2.
I have been getting these error messages ever since. I am not able to use my hosting environment properly.
The error messages read that apps like powershell.exe w3p are trying to delete objects.
I’m no longer able to create new users now. Please give your suggestions.
Should I try to create the working environment from the beginning?
Is there another solution?
Please help me.
Zaman71
Problems using Microsoft exchange 2010 in service pack2
Microsoft Exchange 2010 is not compatible with Windows XP Service Pack 2.
You have to update your Windows XP Service Pack 2 to Windows XP Service Pack 3.
This is an easy task if you take help from the internet. Just get your machine's update session on.
It will automatically update your Windows XP from Service Pack 2 to Service Pack 3.
You can also download Windows XP Service Pack 3 and install it accordingly. It may take several minutes.
Take extra care during updating Windows.
I think it will be helpful for you and all other problems will consequently be cured.
I hope you understand it.
