Problems with the update version
Hello experts,
I'm facing a few problems with the update version. Firstly, the settings don't amass for me, but this can be kept away by putting all in the class-active-directory-employee-list.php file.
After doing that, I get 2 errors after searching on a page through the short code, the widget display nothing.
Warning: ldap_search()[function.ldap-search]: Search: Bad search filter in: adLDAP-extended.php on line 255
Warning: ldap_get_entries() expects parameter 2 to be resource, boolean given in adLDAP-extended.php on line 259
Help me. Thanks in advance.
Answered By 10 points N/A #98743
Hello man,
You have written and written. You have written that you are facing problem with the updated version. But what does version mean?
You have to mention your application name. I think you are talking about a plug-in that is making your problem as you mentioned class-active-directory-employee-list.php file.
But you did not told what was your previous version and what is the latest version you have upgraded to. You might have missed to check if it was compatible for you.
Please contact with the person or company who had made it. They may solve your problem.
However I do not know if I am right or wrong.
You can go back to your previous version.
