Problem for Zipping files or folder
I have tried to zip a folder on my computer. The following error message shows "Error(740): The requested operation requires elevation.". What should I do or is there any other way to zip my files without error?
Answered By 0 points N/A #80871
To solve your problem. what software are you using to zip your folders. the best software for zipping your folder are Rar or Ziper. you should have to download a Win Rar software from the Google or any other site. the best site which provide free software is download.com. you should have to download Win Rar from this site and install on your computer. then select the folder you want to zip right click on the folder and select the option add to archive and click next it will display a window which show the Rar or Zip option select which is required and then click ok. that's it. thanks for asking in techyv.com
Another Zipping utility that you can use is KGB Archiver. You can use this as a compression tool. To download and install, please watch the video below:
