Problem with wmp.dll in Windows Media Player
Hello. Just got this error on Windows Media Player: “The file wmp.dll has a version number of 9.0.0.3075 where 9.0.0.2980 was expected”. Windows Media Player is not installed properly and must be reinstalled.” I’ll greatly appreciate a solution to this problem. Thanks in advance.
Answered By 0 points N/A #153453
Hi Carol!
Try to follow the methods below to fix the issue:
Method 1
1. Go to Start.
2. Type Run on the search box.
3. Click Run and type C:Windowsinfunregmp2.exe/UpdateWMP
4. Press Enter.
Method 2
1. Go to Start.
3. Click Run and type regsvr32wmp.dll
4. Press Enter.
Method 3
1. Download the latest version of Windows Media Player here https://support.microsoft.com/en-us/help/18612/windows-media-player.
2. Run the executable file then install.
Make sure that you download the version compatible to your system.
That's it! Hope you fix your problem with these methods. Thank you for reading!
