Problem with Windows 8 installation
When I am trying to install Windows 8, the driver CD is not loading and exiting the installation. Please help me to find out the driver for graphic card. Please guide me to sort out this issue. I will thankful for all help and support.
Answered By 20 points N/A #93625
Hi Zinnia,
Have you checked if your computer met the minimum system requirements for it to run Windows 8? It may be what is causing your problem. To run Windows 8, your computer must have 1Gigahertz or faster 32 bit or 62 bit processor; 1 GB of RAM for 32 bit to about 2GB of RAM for 64 bit; 16GB of hard disk space for 32 bit and 20GB for 64 bit; and, DirectX 9 graphics card. If your computer has not met the below requirements, then most likely that is why the installer is not loading. You may also want to check if the CD is working by using it on another computer.
Aristono
