Problem While Configuring DNS Manually
While installing DNS I received an error message. The screenshot of the error message is as under.
It suggests configuring DNS manually. How can I get a remedy of this issue?
Have you any idea?
Please help.
Thanks in advance.
An error occurred while the wizard was installing DNS. You will have to configure DNS for this domain manually
Active Directory Domain Services Installation Wizard
An error occurred while the wizard was installing DNS. You will have to configure DNS for this domain manually.
Answered By 5 points N/A #143094
You should make it sure that the workstation has DC as a DNS address only. But if you are using DHCP make it sre also that the server is providing the DC as a DNS address ONLY. Check the configuration of DHCP , it should be appropriate such as:
Option 003- Option for gateaway address then put it in Router’s IP address.
Option 006- Option for DNS address. Put it in DC’s IP address ONLY.
Option 015- Option for domain FQDN. And enter your AD DNS name ( “domain.local” for example) Then Enter.
To configure a forwarder, Go to the Open DNS console. Right click the Servername. And choose properties. Go to the Forwarders tab and enter your DNS address of your ISP. Run ipconfig/release then ipconfig/renew to get a new DHCP configuration. Join this to the domain.
Hope it will help you.
