Problem using PCDMIS on Windows 7
Hello
I am using Windows 7 and I am trying to load 2011 MR1. When I started PCDMIS for the 1st time I got the following errors:
Unable to write to the registry. Please verify that you have write permissions for this option: Section = option key = Dph9_m90180 Value = Y plus
Unable to write to the registry. Please verify that you have write permissions for this option: Section = option key = Dph9_m90180 Value = Z plus
Unable to write to the registry. Please verify that you have write permissions for this option: Section = option key = tool change pending value = 0.
I have full rights on the PC. Also FYI is for a Romer arm. I have posted here as well as on the forum feeling the registry problem isn't specific to a Romer. But there's no activity on that Forum. I also contacted some tech support but without any success.
Please help. Thanks in advance.
Best Answer by Maxwell Mark
Answered By 75 points N/A #106129
As you are using windows 7 and trying to load 2011 MR1 and started PC-DMIS you come up with certain errors, Please try with the solutions described below.
Well, even if you have full rights on the PC, just right click on PC-DMIS icon and select 'Run As Administrator'.
Only once you have to do, and then you can open it normally.
Answered By 0 points N/A #194980
Here are examples of how to solve this:
Unable to write to the registry. Please verify that you have write permissions for this option: Section = option key = tool change pending value = 0.problem
Just install it on a 3000i Romer arm, then open the file by running it as an administrator. I feel that this is a very appropriate answer for this problem. Thanks for asking on techyv.
Best of luck,
Maxwell Mark
