No of visitors who read this post:
223
Category:
Windows Mobile OSs
Type:
Question
Author:
Kevin Moiles
I have unrooted my bionic 5.5.893 using petes Motorola root tools, however I cant seem to uninstall the Superuser app. I have tried to repeat the process and completely restore my bionic and still nothing. If I go to manage app it will not give me the option to uninstall.
Any help regarding this will be appreciated.
There are some types of softwares which are not totally removed by ‘Add and Remove’ option in control panel because there are some registries left behind after removal as in your case or they are not shown in the add and remove options. For uninstalling such type of software Download software named revo uninstaller.
Hi Kevin,
Please follow the instructions to uninstall your software.
1. At first, choose the program you need to uninstall. Then right click on it and select uninstall.
2. The choose advance and press next.
3. Press on select all, delete and then next.
4. Again select all, delete and then next.
5. If it works, then click finish.
