No of visitors who read this post: 185
Category: Hardware
Type: Question
No votes yet
I have a tv tuner which was working perfectly until now. Recently there has been some problems with it. It is not responding. It does not show anything that might prove that it is working. The indicator just shows that it is turned on but nothing else. I have tried to on/off but it is no use. Should someone know of this problem kindly help me out.
Herbert Welling
Comment viewing options
I think there is some technical problem with the TV tuner. However, check its connectivity first. Then make sure about input and output cable. You can lose all the cables from it and fix them all again carefully. Remove dust or something like this if available on it. Turn on and check the status. On the other hand, as its power supply is ok, it’s the problem with the tuner. Contact a good technician to make it alright or follow the guidance made by him. You can also contact the customer care of the respective brand. They will confirm you about its status.
I hope you understand it.
Thanks
