No of visitors who read this post: 665
Type: Question
No votes yet
Hi, can anyone help me on this problem please? I have been getting the error below when I run Anarchy Online in my Wine 1.3.29 Mac OS X 10.6.
Code:
“<Error>: kCGErrorIllegalArgument: CGSGetWindowBounds
<Error>: kCGErrorIllegalArgument: CGSGetSurfaceBounds
<Error>: kCGErrorIllegalArgument: CGSBindSurface: Invalid window 0x1854
<Error>: unknown error code: invalid drawable”
The game was also completely black and was in windowed mode.
I tried to use a virtual desktop and the game run without these errors. This was also the case when I tried to plug an external monitor.
Can anyone give me any feedback on this? I want to be able to play normally on my Wine 1.3.29 Mac OS X 10.6 again. Thanks.
Comment viewing options
Hay Edward Graham,
This problem caused for over installing on your processor. You may need to play on legal way. Thus over files would miss its configuration.  So this is not play at all.
Check your "C" drive or existing file folder. Then you can apply by safe mode. Safe mode can fall on your processing. So you have to uninstall the program in this existing file. Restart the computer and set up the file again.
Do not use any illegal software. It will just add problems to your computer. Above term can help you better. Remember of course you uninstall until it completely and trash from your folder.
