A problem with my software adobe Photoshop.
A problem with my software adobe Photoshop. I am editing a photo that needed to be submitted next week for a school project, our professor will pick the best one and it will be considered as exempted for the final exams.
However while rendering the file, the Adobe Photoshop application crashed and never let me save my work.
What would be the main cause of the problem and how can I recover my work?
Ericson Eric.
Answered By 0 points N/A #186252
Hi Ericson Eric,
First you check the minimum system requirements for windows
Intel Pentium 4 or AMD Athlon 64 Processor
Windows Service pack 3 or windows 7 with service pack 01
1 GB Ram
1 GM Available Hard disk space
1024 x 768 display (1280 x 800 recommended) with 16 bit color & 256 MB of VRAM (Virtual Ram)
Try this
Change the screen resolution to 1024 x 768 or 1280 x 800
Hope this solution will rectifies your problem
Thanks & Regards
Mckinney Ma
