Problem with my DVD Rom when not in use
i am using a desktop pc which was bought 2 years ago. recently my DVD writer started going mad. it mysteriously comes out and stays. when i put a dvd and send it back in, it detects it and runs the dvd. but when nothing is in it, the tray comes out. i was wondering whether it could be a virus. but since it happens even before OS loads i came to a conclusions that its not a virus. so someone please tell me a solution for this problem.
Best Answer by Maddy U
Answered By 0 points N/A #119811
Heshanera
This is a hardware issue. However to be very sure, you can place another Cd Rom Drive or DVD writer just on temporary basis, and check its behavior. If you do not see any such occurrence, than come back to the hardware.
Possible the Puck behind the DVD writer, OR its belt may have become faulty.
As long as the DVD WR is working ,you should avoid giving it to any mechanic, simply forcefully close the tray.
Answered By 0 points N/A #119812
Dear Heshanera
     According to you, ".i was wondering whether it could be a virus. but since it happens even before OS loads i came to a conclusions that its not a virus", so you are sure that it is not a virus, did you download too much software to your hard disk? Sometimes, the too much installation of different software can cause of slow performance of your computer system. According also to you, whenever you use your DVD Drive, it just bring back the cd outside, one reason that I can see is the part of your DVD, one thing that I notice with my DVD player when happens to face an error just like you is that, the player would not receive any cd due to the system overload and system defect. Your DVD may have too much residue inside, like dust or dirt, you have to clean that and make sure that your DVD writer is clean because it may also cause error to your system.
