Problem with Milagrow M2 Pro camera?
Hi guys, I want to know why Milagrow M2 Pro camera is not clear though it’s camera specs is 8 mega pixel rear and 2 mega pixel front camera forget about the front camera the rear camera itself is not clear at all its kind of VGA.Even VGA camera quality is better when compared to it please tell me is there any way I can fix this priblem or shall I ask my money back it also has other annoying features.Thanks
Answered By 10 points N/A #189086
Higher number of Mega Pixels is not a guarantee of good pictures. You may prefer shots from any 8 mega pixel camera over 16 mega pixels. There are lots of factors which affect the quality of the photos. Some of the important basics are:
Lens: size and the material from which the camera lens is made, play a very critical role in the photographic performance.
Flash/light sensor: This is, indeed, the bar setter in the among SLR cameras and smartphones, you may have seen, that any SLR with say, 8 mega pixels can easily outperform a smartphone camera of 15,16 megapixel resolution. This is just because of the physical size of the sensor. Bigger sensor, more light can be captured by pixels, resulting far better pictures.
Moreover, overall software and image processing hardware is also very important.
Now I hope you understand this fact better.
