No of visitors who read this post: 113
Category: iPod
Type: Question
No votes yet
Hi everybody,
My iPod has been fine until I synced it for a second time. I've searched online, but there seems to be fixes for people who sync all of their music to their iPod, but I do it manually. Does anyone know how I can fix this?
Comment viewing options
Hallo,
The best resolution on your case will be to get rid of all the music that you have on the iPod and then after that try syncing again and see if it will work. The device may take a bit long when syncing but it will be successful.
In the event that you sync photos, then that is all the iPod will sync. That may cause a problem like the one you are getting in the event that you have got a lot of photos on the device and you do not want them to synced at once until other files like music and videos have been synced.
Hope this helps.
Carl
