Problem I could after updating IpodTouch
I updated my iPod Touch third generation with the version 5.0 of iOS, then I configured it with iCloud and with my Apple ID. It works normally. After that I tried to connect my MacBook to iCloud with the same Apple ID. I am having a problem here: error message from iCloud “The login is currently impossible”
Answered By 0 points N/A #95191
Hello Steph!
We have the same problem encountered in  iPod Touch third generation. I also experienced that problem few days ago when I tried to connect macbook to icloud. First, I suggest you to activate your AppleID'S email address and be verified. I also recommend you to use AppleID same as your email address. If this won't work for you, try to change your primary address into a new one and then make sure to activate it. Just click the activation link on your email which you'll receive after changing your primary email address. This worked for me and I can now connect my macbook to icloud. I hope this one would help you solve your problem.
-Johnnyd
