Problem on ac3 extractor installation.
I got a problem in installing the ac3 extractor in my computer with windows 7 32 bit operating system. Installation is always unsuccessful is this a compatibility problem or drivers? Give me a solution. I really need your help.
Answered By 590495 points N/A #154066
If this is the first time that this happens, try restarting your machine then try it again. Check if it’ll work after restarting the system. But if still not, if the installer you have was downloaded from a website, visit that website again then check for the program’s system requirements or maybe some other technical information regarding the software. This will help you in determining if it is indeed an incompatibility issue.
You should also check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics test on your machine, use disk utility applications like Norton Utilities, PC Tools Performance Toolkit, or Norton SystemWorks.
