PowerPoint’s Highlight Text feature available in Android now.
Explain how can we use the Microsoft PowerPoint's Highlight Text function in an application of Android Tablet?
Best Answer by Recorter Qyut
Answered By 5 points N/A #163180
Hi there,
What you will need is to download and install the Kingsoft Office.
This is explicitly made for Android tablets.
You can download the software from the Kingsoft official website:
  • The thumbnail list has the PC Office for easiness of sliding switch.
  • Features such as the New, Duplicates, Delete and Move Slides.
  • It has the setting for slide layout.
  • You can edit on rich text format such as Bold, Underline, Italic, Paragraph, Insert picture and a lot more.
  • It has the capability to display WordArt, pictures that are already cropped, charts, tables and many more.
  • You can also edit the text in slides and highlight it so it can become viewable to the readers.
Hope that helps!!
Answered By 5 points N/A #163181
The only way to use PowerPoint, Microsoft Word or Excel, is by buying another application.
I have highlighted some of the applications you can purchase below; Your choice depends on whether you want to view the documents, create and/or edit documents.
  1. Documents to Go – Has both a free, limited use, version, and a full version. You can download the free version of "Documents to Go" from either Google Play, or Amazon AppStore.
  2. Quickoffice Pro HD – Another great app for viewing and editing Word, Excel, PowerPoint, and PDFfiles is Quickoffice Pro HD. The HD version is optimized for tablets. They no longer offer a free 7 day trial, however, this app has just been purchased by Google.
  3. OnLive Desktop – A new cloud option which requires internet access to use. If you are able to be connected to the internet, it will allow you to open a virtual Windows 7 desktop session via a cloud service. The application will present a Windows 7 screen with icons to open PowerPoint, Word or Excel
