No of visitors who read this post:
230
Category:
MultiMedia Applications
Type:
Question
Author:
Evelyndnell
Hi guys,
I am using adobe Photoshop version 13.0 for the last two months now. When I select the tabs "preferences", "interface" and "open documents as tabs", I see a tabbed interface but I don’t want such an interface. To get rid of such an interface, I deselected the tabs but now I am facing a problem. When these tabs are not selected some of the commands do not function properly.
I cannot copy paste a layer from any other file. Each time I get the following error on my screen:
I cannot put up with the tabbed interface. Can anyone help me in this regard? I'll be grateful for your suggestions.
Regards
Joseph
Dear User,
I advise you to simply reset your Photoshop settings in to the default. In order to do this, Press Ctrl+Alt+Shift together.
Now while keeping these buttons held, open Photoshop,
Now you are being asked a question, whether to delete your existing setting file. Click yes.
There you go,
Hope your problem will be solved
Thank you.
Hi there user:
I suggest that you should uninstall your application/version first, and then install it again. You may also want to upgrade it. And when done, be careful of setting-up the settings, figure it out so there could be no more trouble while you’re using it.
I hope all we be done well.
Thanks for visiting techyv.com
Edmund Joseph
