Photoshop basic and alternative for product imaging
I am currently looking into a career into advertising and more specifically product imaging. I am a novice at using Photoshop. Can anyone point me to ways to learn the basics to Photoshop? Also I wanted to ask whether Photoshop is the only program for image manipulation or are there any simpler program?
Answered By 0 points N/A #185126
The standard software for photo publishing are Coreldraw and Adobe Pagemaker. Photoshop is itself a simple software, mainly used for photo manipulation and / or freehand drawing. You can learn basics of Photoshop from YouTube, but for advanced functions you can take an online course. I will suggest you start with Photoshop 7.0 then upgrade it to CS 3. For a much simpler photo manipulation Picasa is also handy.
You can download Picasa from the link below:-
https://picasa.en.softonic.com/?
Below is a snapshot of the same.
