Photomatix pro has stopped working
Photomatix is one of my favorite software on image editing, it is easy to use and have many features, I don’t know what's causing this problem, sometimes photomatix stop but sometimes not, any idea?
Photomatix Pro
Photomatix Pro has stopped working
Windows can check online for a solution to the problem.
Check online for a solution and close the program
Close the program
Hide problem details
Problem signature:
Problem Event Name: APPCRASH
Application Name: PhotomatixPro.exe
Application Version: 3.0.3898.19125
Application Timestamp: 4c81163a
Fault Module Name: StackHash_168f
Fault Module Version: 6.1.7600.16559
Fault Module TImestamp: 4ba9b802
Best Answer by Carl Jack
Answered By 10 points N/A #146700
Hello Joby,
If you have the serial number to that application, then I will recommend that you just uninstall it, and then download a fresh setup application and use it for reinstallation.
As an alternative, you can just turn off debugging that sometimes causes the Just In Time error to occur.
Another workaround to that issue if the following:
  • Check if you have any periods before any .xmp file saved presets.
  • In case you have saved a preset with an additional period, it will make tone mapping inoperative.
  • So you will need to make all hidden files and folders and then look for that error and eliminate it.
Carl
Answered By 5 points N/A #196473
First option is to try to update the graphics card drivers and then check if your problem is fixed.
A second option is to check if the error has to do with your windows. Try to run a ''Clean Boot''. This helps to eliminate any software conflicts.
A third option is to check the version of framework if it is compatible with the Photomatix.
For further information you could contact with the ''Photomatix Support Team''.
