PDF file change to DOC file
Hi and good day TechyV users and friends!
I am having problems about my files. I have 6 PDF files that I want to change to DOC, and I don’t want for manual input of it. Here is my set of questions, how can PDF file change to DOC? Is there a software that can help me? If yes, where can I download it? Any help would be nice.
Shawnj Cruz
Best Answer by Parisi Petrusic
Answered By 0 points N/A #168482
I understand your concern. Here is a quick online solution. If your documents are not too personal or sensitive then you can visit the site below, upload the pdf documents and can obtain doc versions.
http://www.pdfonline.com/pdf-to-word-converter/
On the same page, as you scroll down, you will see comments made by so many satisfied people who acknowledged that the tool had been able to successfully meet their needs. Please give it a try.
Hope it helps.
Best Regards,
Parisi
Answered By 0 points N/A #168484
Dear Shawnj Cruz
Here is the solution for your problem, this software does not only convert PDF to Word but also in text format (Txt) and Tiff (Tiff) and the program automatically resizes the converted documents. Please down load the software from the following link; https://convert-pdf-to-word-desktop-software.en.softonic.com/ . All the best.
Morris Jermaine.
Answered By 590495 points N/A #310918
That would be easy using online tools. If you simply want to convert some PDFs to Microsoft Office Word DOC format (*.doc), go to Convert PDF and other documents to Word. This online tool allows you to convert PDF files (*.pdf) into DOC file format (*.doc). You can upload the files in four ways:
  • Select the files directly from your hard drive
  • From Dropbox
  • From Google Drive
  • By URL
Once the file is uploaded, just click “Convert file” to begin the conversion. This Microsoft Office Word converter supports the following conversion paths:
  • DOCX to DOC
  • ODT to DOC
  • SXW to DOC
  • RTF to DOC
  • WPD to DOC
  • TXT to DOC
  • PDF to DOC
  • PDF to word
  • HTML to DOC
Once the conversion is complete, you can download the file immediately. You will not be asked to provide your email address to download. Note: you can only convert one file at a time.
