PC crashed when playing high quality games and then close
Asked By 130 points N/A Posted on -
Why does my PC crash when on gaming high quality?
Best Answer by thinthin
Answered By 0 points N/A #85725
Try using the on board video if you are using a video card.
Answered By 130 points N/A #85727
Yes, I'm using a video card. If I use the on board video and then the problem goes away. How can I justify if the video card has the problem?
Answered By 0 points N/A #85729
Also try using software tester like memtest86, occt, furmark. You can also check for the maximum resolution and frequency of the monitor.
Answered By 130 points N/A #85731
Okay. Thanks for the help.
Answered By 75 points N/A #85732
Your OS are not compatible to your board
