I have created a simple database with 12 fields both text and numeric.
The query I’ve chosen shows the value of each field.
Why can’t the query see the database and gives me a parameter query box for every field when I shut down the database and reopen it?
I should specify that when I save the query, close it and re-open it works just fine.
Parameter Query Box For Every Field
Hello!
A parameter query is an advanced query. You can create a query that can be updated easily to refer to a new search term.
In parameter queries, search terms act as variable criteria and change each time you run the query.
The solution to your problem requires a very detailed solution, however I was able to find some useful links for you.
Use a parameter to make a query ask for input
Customizing Access Parameter Queries
Hope it helps.
