When i am using TOAD to administer our oracle database,
I meet an error that tells me ORA-00942: table or view does not exist.
I came across this error every time I am compiling an object, package, view in oracle, and sometimes when I execute PL/SQL statement on Oracle table. It also happens when I run an application, specifically oracle program.
I already scanned some books and did some browsing over the internet, but I have a hard time looking at the solution to my problem. It took a lot of my time looking for the solution, please share some ideas and points to my issue.
(Solution Accepted)
Submitted by Phani on Sun, 2011-07-03 16:48.
Comment Id: 16669
Hi Mark,
Whenever there is an error while compiling any object, then the issue is related to access whether you have privilege to access it or not.
- Database table does not exist means you are not permitted. Grant privilege on object to user;grant select, insert, update and delete on package to user; these are syntax for grants.
- Object itself is invalid. You have to identify invalid object and rectify it by compiling with some techniques.
- We can check invalid objects by using select object_name object_types from user_objects where status = "invalid". Compiling can be done in following ways:
- ALTER PACKAGE my_package COMPILE;
So on compiling with body,
- my_function,
- my_trigger,
- my_view (just replacing with these in place of my_package).
These are the procedures to find invalid objects and compiling and.
NOTE: basically its better to recompile those invalid objects in repository itself.
(Solution Accepted)
Submitted by Kamal on Sun, 2011-07-17 10:11.
Comment Id: 18134
Hi Mark,
I think that your tables are not being accessed onto other schemas. This problem emerges even when the tables have proper access rights. There can be two solutions:
Either you prefix your Table name with schema name
e. g. <schema_name>.<table_name>
2. Or what I can really suggest is to make 'Public' synonyms for the tables. I believe that this will solve your problem.
Thanks,
Kamal.
