After using Google Chrome for quite some time now I decided to try and install Opera. It works perfectly for me though until today. I am faced with the error message that says “Crash log writing failed, couldn’t debug process! Error description from system: The parameter is incorrect”. What happened to my browser?
What will I do so that I will not be able to get this error message again?
Crash log writing failed, couldn’t debug process! Error description from system: The parameter is incorrect.
Opera error Crash log writing failed, couldn’t debug process
You're using a beta version of Opera and you should have read the known issues included on that version. It is unstable and has several known issues including crashes and data loss situations. Sure your system is fine, you may just have to wait for the next Opera full version release. The developers are still handling the issue according to the site.
You need to change the browser identification from identify as opera to identify as Firefox. You need to do this and then the problem will be solved. For this purpose you need to follow following steps:
Go to Menu -> Settings ->preferences ->Advanced (Tab) -> Content (Tab in the left side list)
Press manage site preferences, "Server Manager" window is opened.
Press the Add Button, give it site name and goto network tab.
Change Identify to opera to Identify to Firefox from Browser identification.
