I just upgrated my system to opensuse 11.1. But it's not working properly. The following message is appearing. The said file resist in harddrive but it is not recognizing. I tried to recognize the file several times by clicking 'retry' but it's not working. What is it's solution? Please let me know.
opensuse11.1 – VMware Workstation
Best wishes,
celvin
Error:
opensuse 11.1 - VMware Workstation
Operation on file "C:\vmware\opensuse 11.1.vmdk" failed.
If the file resides on a remote file system, please make sure your network connection
and the server where this disc resides are functioning properly. If the file resides on
removable media, reattach the media.
Choose Retry to attempt the operation again.
Choose Abort to terminate this session.
Choose Continue to forward the error to the guest operating system.
Hi friend,
Opensuse11.1 – VMware workstation is complicated software. It will create problem at the time of running this software if you have any hardware problem in your pc. So do three things to run Opensuse11.1 – VMware workstation.
1. Remove viruses. Scan all computers with excellent virus scanner and clean your pc. Do not hesitate about deleting any corrupted files or folders. Remove all threat for your pc.
2. Install software to test your hardware. If you have problem with hardware then repair that. If it is not possible to repair then replace it.
3. Last thing to check is Opensuse11.1 – VMware workstation software problem. You may have to install a new copy of this software.
