Notify the ways to protect computer from viruses in steps.
Notify the ways to protect computer from viruses and the steps for the same as well and revert soon for it and thank you.
Answered By 80 points N/A #285107
Hey,
The ways to protect computer from viruses can be done by below listed things to do:
• First keep the systems software up to dated for the scanning
• Do not open the unwanted link over the mail
• Can use the firewalls as well
• Make use of the free or buy antivirus as well.
• Can back up the systems too
• Try to make a strong password for the systems too
• Make less download too
• Make the use of the pop up blockers as well.
PROTECTD
Answered By 590495 points N/A #288290
If you are very keen to protect your computer from any form of computer viruses, your computer should be installed with a reliable antivirus or internet security software. If you don’t spend much time on the internet and you mostly use your computer offline or not connected to the internet, you can stay protected using an antivirus application.
But if you spend most of your time on the internet surfing different websites, it is recommended that you use an internet security application to add protection against rouge and harmful websites. If you only need an antivirus, one trustworthy brand you can try is ESET NOD32 Antivirus. The latest version supports Windows Vista, Windows 7, Windows 8.x, and Windows 10 including Windows Home Server 2011.
Also, the latest version no longer supports Microsoft Windows XP. If you need an internet security program that can protect you whenever you’re online, you can try ESET Internet Security. You can also access other ESET security products from ESET Antivirus and Internet Security.
Aside from having a dependable security program, it is also important that you make it up-to-date or update it regularly so the application is equipped with the latest protection it can apply on your system. Remember, an effective and dependable security application is useless if it is not well updated.
