Hi,recently I am encountering an error when I am trying to open one of my revit file.I have not seen this kind of error before. How can I get my revit file back ? Please help.
Error: Seek failed on Z:\Data files\08190.010 Sabatini Residence\MODELS\revised scheme\sabatini residence revised scheme 04 REV.BATH.rvt
I think it is not any system error or fault. From your image posted above I come to a decision like. You have created the problem. By using periods in your Revit file names, you are inviting the problem. So, stop using periods in your Revit file names. Problem will be solved immediately - I think.
Have your problems solved?
Thanks for asking.
Hathy
