Not able to download MPW with Frostwire
I’m using Frostwire and when I’m going to download an MP3 file, it gives me an error message like "there was a problem sending the command to the program." I receive this message in a separate dialog box or window and when I close it, it downloads sometimes. In most cases, it fails to do so. What shall I do ?
Can anyone please help me ?
Best Answer by Glenn Mcgaughey
Answered By 60 points N/A #176986
Hello Travis P Tarver,
How are you today, I think can help you with this problem. you try to run CCleaner, I do not think this is a FrostWire related problem. You can try the software, set option first.
 I hope that will work.
Have a nice day.
Thanks!
Nathan H Underwood
Answered By 0 points N/A #176987
I also believe that your problem is not related to Frostwire. I’ve read about this problem and even people without Frostfire encountered this. But you can still try to uninstall Frostwire then install again with the latest version. Try also to upgrade your version of Java. If you still have a problem, try to clean uninstall Frostwire with Revo then install it again with version 5.3.4.
Hope this works for you.
