Norton Antivirus Error Message on iMac
Hell there!
We have migrated my software to my personal brand-new iMac, managing 10.5 merely I have got this error message:
Norton Antivirus Automobile Shield couldn't go forward. Make sure you re-install Norton Antivirus in addition to reactivate.
I've uninstalled Norton but my spouse and I however still have the content, we’ve deleted all Norton documents excessively nevertheless it placid pops up and I also would like to eliminate the mistake concept.
Why does it happened? And just how may I delete this?
Symantec AntiVirus Error
Symantec Antivirus Auto-Protect could not continue.
Please run live update or reinstall Symantec Antivirus and restart. (Code: 10)
OK
Answered By 590495 points N/A #92935
I think the installation for your Norton Antivirus is damaged that is why it cannot start the Auto-Protect function. With Auto-Protect enabled on your computer all the activities in the computer are being monitored by Norton Antivirus especially every time you launch an application.
If your Norton product is damaged and can not start during startup, use Norton Removal Tool to remove all Norton products that are currently installed on your computer. This application will clean your hard drive from any left components of your previous installation of your Norton product that is causing the problem. You can download Norton Removal Tool.
After downloading it, double-click it to launch the application then follow the on-screen instructions. After your computer has been cleaned of any remaining components and files, you can now install again your Norton Antivirus.
