No of visitors who read this post: 616
Category: Mobile Hardware
Type: Question
Your rating: None Average: 3 (1 vote)
Why can't I install some apps like Skype?
Can you suggest some compatible apps for my Lumia and if there's something.
I could do to make the apps work please tell me.
Comment viewing options
According to Nokia, they said it is the below par user experience is the reason why they don't support Skype app for Lumia 610.
But actually your Lumia 610 is not able to run the popular mobile apps like Angry Birds, Skype, PES 2012 because of it's lower hardware specifications. The minimum memory required for a smartphone is 256 Mb and Lumia 610 has that 256 Mb only.
You can go for some simple apps in Lumia 610. You can find those in the Windows Market Place. Link to Windows Market Place
Also you can find some free apps for Lumia 610 in the link
There is nothing you can do in this context other than installing apps which require lower memory or to wait for the app developers who will develop a compatible app for the Lumia 610.
