Next receiver download instruction which is better to use
I've got a Next Receiver that has 1-2 HDMI outputs with enhanced sounding and very easy to use. But the problem is I don't have the instruction on how to operate it. I lost the manual. Where can I get a copy of its instruction manual? Please send me the link. Thanks.
Answered By 0 points N/A #179805
I have got full manual instructions for your Next Receiver HDMI outputs. You can download full instructions in PDF format from the given link.
http://downloads.kinivo.com/product/manual/501BN%20User%20Manual.pdf
The important safety instructions:
1.    Do not remove cover of the unit to prevent risk of electric shock.
2.    Avoid to use the switch near water.
3.    Use dry cloth to clean.
4.    Do not install this unit in a bookcase.
5.    Only use accessories provided by the manufacturer.
6.    During lighting storms unplug this unit.
