NetApp ONTAP 8.1 Simulators errors
I need to have multiple simulators to work with OnCommand and  that is why I copied and added simulator into NetApp Management Console but now I am getting this error messages. What should I do to ignore this error?
Error details:
Host sto-fas3.mtellin.lab (197) already exists.
Error details
Host already exists. (error 22311)
No suggested corrective action is available.
Copy to clipboard
Answered By 10 points N/A #131357
Hello Greg,
It seems like you already have the simulator files installed on your computer. If you had already installed the files prior to running the installation, you will need to do the following;
  • There may be files or registry entries associated with the simulators that are still on your computer and therefore there preventing the installation from running successfully.
  • You will therefore need to install CCleaner on your computer.
  • After that execute it and the use it to fix all problems with registry entries and as well remove any files associated with the simulator on your computer.
Hope this helps.
Regards.
Carl
