Need to structure my search phrase
I need to structure my search phrase. Getting problems with lemmas. Individually these lemmas work to identify the correct verses.
However I then want to find just the verses where they are both present. I have tried
lemma: ה.2 NEAR lemma:אם.4
but it produces 0 results. Does anyone suggest me how to do it, I mean the correct procedure of doing the structure?
Error writing to file:
Logos Bible Software 4
C:UserstcblackAppDateLocalLogas4SystemLibronix.DigitalLibrary.Resourcess.dll
Verify that you have access to that directory
Please wait Windows configures Logos Bible Software 4
Thanks
Answered By 590495 points N/A #144754
I think this problem is from within the application. Please make sure that the version of the program you are using supports your operating system. You should check the program’s system requirements to make sure you are running a compatible software. If there is no system incompatibility issue, reinstalling the application might fix this problem. Uninstall the program first then check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities, Norton SystemWorks, or PC Tools Performance Toolkit. Install the program again after this.
If it still doesn’t work, try upgrading your program. If you are using an older version of the application, try upgrading it to the latest version if there is an available that supports your operating system.
